Tries to resist… fails…
bet·ter 1 (btr)
adj. Comparative of good.
1. Greater in excellence or higher in quality.
2. More useful, suitable, or desirable: found a better way to go; a suit with a better fit than that one.
3. More highly skilled or adept: I am better at math than English.
4. Greater or larger: argued for the better part of an hour.
5. More advantageous or favorable; improved: a better chance of success.
6. Healthier or more fit than before: The patient is better today.
adv. Comparative of well2.
1. In a more excellent way.
2.
a. To a greater extent or degree: better suited to the job; likes it better without sauce.
b. To greater advantage; preferably: a deed better left undone. See Usage Notes at best, have, rather.
3. More: It took me better than a year to recover.
n.
1. One that is greater in excellence or higher in quality.
2. A superior, as in standing, competence, or intelligence. Usually used in the plural: to learn from one's betters.
Sorry about that 🙂 Obviously "better" is subjective but some things aren't, frinstance the Orange has a bit of a more limited design brief, it's designed as a "lightweight steel hardtail" for a 100mm fork, it'll carry a longer one but it's recommended for 100mm. The Soul works very well at either end of its travel, the new one'll be exactly as good as the old one at 100mm (very nice) but also takes 140mm of fork (also very nice).
Weight will be interesting, I did see one place quote it as 4.5lbs for the medium which is heavier than a Soul, but I'm not convinced myself. It's longer and a little larger so has physically more tube in it, but then it's not built as strongly.
The main question to me is just why is it so expensive, for a far eastern frame? What makes it £80 more than a Soul, when it actually seems like a slightly more basic design? (less reinforcing, no replacable dropout).
