How hard is it to thread a hose through a swing arm then.
Anyone got a good tip on how to do it ?.
1) When you remove the old brake, attach a piece of string, then leave it in place. Then, use the string to pull the new hose through.
2) If you’ve already removed the old brake, throw bike into sea, take up crochet
Actually it’s not bad on an Orange, even if you have- remove the rubber grommets, attach a weight to some string, poke it in at the frame end, it’s pretty easy to get out at the brake end.
Oh they mostly use the same hose for either mineral or dot fluid. You can’t be absolutely sure that OE will work for both- I’d personally bet money that it will. Or that it’ll work with your hose unions. But any aftermarket kit will be compatible with both, just because there’s no reason for it not to be.
Superstar’s hose kits are sometimes better value than OE, and are perfectly good. What brakes do you want to fit?
