Cheers. Its been pointed in lime mortar so in two minds whether I should seal it or not, likes to breathe lime mortar apparently, chap said to use linseed oil if I do.
@ononeorange just the bricks in the first pic, and the four that are resting on the arch in that pic.
What do the stove fitters attach the registry plate to? the arch or the inglenook sides
@GR @bigblackshed cheers, I think the lintel one would seal against stuff coming down the chimney more? or do you guys have vermiculite packed around the flue?
and these don’t even feel like a tile, entire half room furnished in them under the underlay, its got to be a 70’s fad surely?! 😆
The brick hearth is complete, pointer was a true craftsman!
Need to decide how to finish the skirting off, either stop at the first hearth brick, stop at the inglenook edge with a cutout, or fill the side skirting in and leave without on front?
Pretty sure the fitters used something like THIS to make an internal rectangle frame which is screwed/bolted around 2 bricks up from the arch then a rectangle of galvanised steel cut to fit and screwed to the frame if that makes sense?
Can do a pic tomorrow if you want and yes vermiculite around the flue, 5 bags worth if I remember correctly.
Moving into a place next Friday with this. Coal fireplace in the middle of all that. No idea what’s behind all the brick. It’s quite nice, but not big enough for a stove, maybe not even with the inner, recessed brick arch taken out.
Depends how old the building is. Might just be a square hole, might be an arch. To be fair a gaping hole will be better than that collection of bricks.
The larger arch is 75cm tall by 75 wide, so still not really big enough for a 3/4kw stove, so Messrs Club Hammer and Cold Chisel will be doing some subtle investigative work.
Happily, there’s another couple of building go nearby that were built at the same time (1930s) by the same people, so some friendly doorstep ping might win me some pointers.
Messrs Club Hammer and Cold Chisel might have to stand back and see what Messrs Drill and Endoscope can find out.
What with the fire surround, the drains, the chimney, the floor voids and the cavity walls, I think I might get my money’s worth out of this! As long as I don’t end up going endoscope crazy and swiss-cheesing my house to look inside things.
Well yes if there’s some neighbours that have removed the fireplace then ideal, get knocking!
A mate with a trailer helped me take our tiled fireplace out. There was a lot of rubble behind the fire inset and extra rows of bricks behind and on the sides for the inset. Glad he had a trailer. 🙂
The plan is to leave the chimney stack on the ground floor, and remove it from the second floor as we’re having a loft conversion…We’ll take out the bricks and have a twin lined steel flue/pipe.
I’ll have a short length of liner from the ‘floor above to the register plate’.
Hello DrP, I was thinking you’d be on here before too long! Very likely to be getting smashy, but now I’ve bought an endoscope I’ll be blimmin well drilling holes in things and looking in dark places.
Didn’t know about SDS drills until just now, and now there’s another item on the shopping list. What did you go for? Happy with it?
“boxelder – Member
OP – how much was the flue pipe and how high does it go. Just taken the sledge hammer to one similar.”
Flue is ten meters long approx, but reckon they cut about a meter off, 6″ 316 grade twinwall. The flue part of it, with chimney downdraft cowl, registry plate made in situ etc was around £900. Asked on here at the time of quoting and that seemed reasonable.
Just had me first fire! Any tips here would be more than welcome!
Went with 10 balls of scrunched up newspaper, 10 pieces of kindling, door ajar whilst it all fired up, closed door and waited for kindling to get a good fire going, then added a log. Closed the primary air vent on the bottom once fire had started, left the secondory air vent on the bottom at 50%, and left the top airwash vent fully open. Not much movement in the top airwash control, but guessing smoke control kit has something to do with that.
I’ve just opened up another one – massive sandstone lintel. Not sure what to do with it yet, may just plaster up and leave the space. 9-10 barrow loads of assorted rubbish, bricks and back burner came out.
Sorry not been on for a while been busy fettlng the stove.
granny_ring – Member
Like that finish what stone is that and which stove are you getting?
The stone is an Indian Sandstone, its very hard reckon its been subjected to a lot of heat and pressure. The stove I went for was a Firefox, a Chinese job which was damaged reduced from £560 to £250 which to be honest havingtaen it apart is all its worth.
WARNING TO ANYBODY BUYING A FIREFOX “DONT” UNLESS YOU GET IT CHEAP. THE QUALITY CONTROL IS NON-EXISTENT
cruzcampo – Member
Looks supurb Dalesrider, that Morso was in great nick for its age too!
I have had the first 2 days of running the stove had a local steel workshop make a plate which is fixed to the chimney using unistrut, 4 allen bolts to undue and the plate is out. I stuck a piece of fire proof cement board in first over the steel work to give it some protection from the heat, probably not needed.
boxelder – Member
@dales rider – did you put the glass in the cupboard doors? Similar built in cupboard here.
Yes I glazed them myself, easy to do just take the panels out from the inside and use a small bead to hold the glass in.
“granny_ring – Member
Looks good. A few small fires with window open until the horrible burnt smell disappeared is what was in our handbook.”
Cheers, there was a bit of a odd smell with first fire, thought it may simply be smoke from opening the door putting in a log. How much smoke smell would you typically get once burner settled in? if any at all?
