Viewing 12 posts - 1 through 12 (of 12 total)
  • OnOne Fatty carbon fork specification
  • MadBillMcMad
    Anyone know the dimensions of the OnOne carbon Fatty fork
    The spec appears to missing from the website.
    I think I am after
    – fork length
    – rake
    – offset
    onandon
    The same as the steel ones
    MadBillMcMad
    Oh thx !
    & so what is the …..
    onandon
    wwaswas
    it weighed in at a piddly 550 grams! The axle to crown is 10mm shorter than the stock fork (470mm) and the offset is 10mm more forward (55mm).
    https://fat-bike.com/2014/06/on-one-carbon-fatty-fork/
    actually the info is on here;
    http://www.planetx.co.uk/i/q/FOOOCFAT/on-one-carbon-fatty-fork
    MadBillMcMad
    thx.
    psycorp
    A trick I’ve learned is that if the info you’re after is missing from the OO website, which as it’s shite it quite often is, always check the PlanetX website as it might be on there.
    You might even find OO mtb items that aren’t even for sale on the OO website on the PlanetX website. 8)
    n0b0dy0ftheg0at
    Don’t forget that this fork has the old school disc spacing (rear), a front disc Spaced wheel will not spin in it without some lathe work on the brake mounts!
    brant
    Certainly when I designed it, the on one carbon fork has the same geometry (and brake mount) as the stock fatty fork. Though not the reviewers stock fork.
    The carbon fibre is from Mitsubishi. The fork isn’t made by them.
    No reason to imagine it’s changed. I did leave the company 2yrs ago though.
    MadBillMcMad
    aye thx all,
    @n0b0dy0ftheg0at, was just trying to see if it was OKish to fit in to an ICAN SN03 frame as a stop gap
    & to minimise immediate expenditure.
    Pretty sure it will fit which means I think) that all I need to transfer everything from my OnOne Fatty is the appropiate Hope hub ends to make my rear Fatsno 190mm.
    Which if so, sounds like a bargain !
    shaggy
    As Brant said, the steel and Carbon forks were designed to the same geometry. 470mm, 55mm offset, 1 1/8″ straight steerer and take rear type hubs. The drawing I checked is 3 years old, but I don’t think they’ve changed it.
    tops5
    I have one I was getting around to putting the classifieds just sayin…….:)
The topic ‘OnOne Fatty carbon fork specification’ is closed to new replies.
