I’m doing up an old house that has an old Ravenheat combi boiler fitted. It’s probably about 20 years old and I’m replacing it with a new Baxi combi. Which I’ve already bought and is sitting there waiting to be fitted. Along with the new magnetic filter.
I don’t want the sludge from the old system clogging up my new boiler so I’m going to flush it first. But as we’re going to be removing all the radiators while the system is down (and as soon as the weather warms up a bit) so we can plaster and decorate behind them I’m planning to flush them all out individually using a hose in the back yard when they’re off.
My question is, what order do I do things in. I initially thoght
1) Run a bottle of cleaner round the system.
2) Drain down, remove rads and hose them out
3) Fit new boiler and rads, fire up and go.
But then I thought it might be better (if more work) to do flush the rads first, then put them back on and run the cleaner round.
What would you do if it was your house?
