Viewing 3 posts - 1 through 3 (of 3 total)
  • One channel Technics 1210’s – where to sstart with a fix?
  • mosschops
    Got me 1210s down from the loft and one has lost a channel – any ideas about what it could be – things to check?
    cheers
    MC
    mboy
    Connection between the Cart and the headshell, and the headshell and the tonearm are a good place to start.
    I was DJing to about 800 people once when I lost the right hand side! Mixed the next tune in VERY quickly, whipped the cart off the offending deck, gave it a quick blow out, put it back on and all was good again.
    MrAgreeable
    Try swapping the headshell over from the other deck. If that works OK, you know it’s probably something to do with your cartridge/headshell/stylus. If it still doesn’t work, check the connections to the mixer.
The topic ‘One channel Technics 1210’s – where to sstart with a fix?’ is closed to new replies.
