How is the chainline otherwise? Is there any potential to move the ring outwards (similiar to how you can flip a raceface cinch ring?) Maybe, fitting a double spider and mounting the chainring in the outer position?
I’ve got a wider Q-factor Raceface Aeffect 100mm crank for sale which would push the chainring out by a fair amount but maybe it’ll screw the chainline in other ways. Is it a 4.0 tyre you have on it?
(on mine, I have a 197 rear and narrower 100mm crank fitted, 1x is fine even with a 4.8 rear tyre… But you have the narrower rear end which obviously pulls the cassette inwards)
