I think I might be needing a new lower bearing for my 1 1/8 inch smoothie regular soon as well.
So, did anyone discover what the code for that bearing would be, please?
I agree with Brant on the grease question, though. So long as the parts aren’t minute and so impaired by loads of sticky grease (like hope freehub pawls and springs), then packing in a load of grease just seems like common sense to me. If grease oozes out when you press two parts together, then that means there is no room for that grease. It follows that there probably isn’t any room for anything else as a result (water and grit for example).
Obviously grease degrades over time, and you might get a bit coming out as time goes by, but it’s much better than having to buy expensive components more often than absolutely necessary.
Anyway I digress. If anyone does know the code for a lower bearing of a smoothie regular, please can then post it here?
