I’ve got a couple- well, Works Components but it’s the same part re-logo’d. Very good- does what it says on the tin really, made in the UK if you care about that, and works better than the Cane Creek Angleset while costing less.
Had a 2 degree one in a Carbon 456- you’ll only be able to do 1 degree I think? And on balance it was an improvement, fair bit better on the way down, slightly better at climbing, not quite as good in tight stuff or on the flat but then it wasn’t that good at that anyway.
Only downside I’ve found is that mine both go through top bearings a bit- I think the flat top of the headset encourages water to pool there and get past the seals, or something. Never had a headset go through tops faster than bottoms before.
