Viewing 8 posts - 1 through 8 (of 8 total)
  • On One Fatty frame weight and 170mm hub options?
  • cynic-al
    As above, it’s cheap, but is it a tank? Seems the steel equivalents are 5-6lb (and yes I know many think it doesn’t matter on a fat bike).
    Also…rear hub? £110 Salsa seems the most reasonable…
    JoeG
    Fatty Dissection thread on UK Fatbike forum found a Medium one of the first batch to weigh 2494 grams with the headset cups still in.
    Some folks were complaining about some of the Surly hubs; they said that the freehub body was cheap with loose ball bearings and didn’t last.
    The On-One hubs are all cartridge bearings (2 front, 4 rear) and stainless steel, I believe. I’m real happy with my Fatty hubs, no issues so far. My only concern was that the freehub body isn’t well sealed. I added grease to mine to keep water out. In fact, I bought the Fatty 29er wheelset and plan to remove the hubs and use them with an more tubeless ready rim when I find one that I like. 😳
    A few others have had problems with their hub end caps coming loose and the pawl spring breaking. On-One has a newer hub design to accommodate different axle standards, so they’ve been changed from the original ones.
    cynic-al
    Cheers. Interestingly the Caribou (a contender, as I am in the trade) has a claimed weight of 4lb 4oz I.e. 2kg!
    I just want the hub only as I already have a spare rim and front end.
    I’ll head over to that thread. I might want to put a front mech on it also.
    JoeG
    I went 2×10 immediately. RaceFace Evolve crank; 24-36-bash and XT for the rest. The 36 is about 1 mm from the chainstay! 😯
    In hindsight, I probably would have been fine with 1×10 as I rarely drop onto the little ring.
    showerman
    am running 1×11 on a beargrease and have no trouble glad i never went 2×10.
    cynic-al
    My guess is that gear choice depends on the riding one does.
    So it’s an internal (i.e. semi-integrated) headset…44 top, 55 or 56 bottom?
    akira
    No idea of the frame weight but my sensible build doesn’t feel heavy to lift or ride.
    gibbonarms
    Fatty’s build to around 33/34lb ish as standard, lighter than a pugs.
    Spot on price for the frame only from On One.
    I’ve had a the pawl spring fail in the freehub body, other than that the hubs have been fine. Lots of problems with Hope Fatsno’s at the moment.
The topic ‘On One Fatty frame weight and 170mm hub options?’ is closed to new replies.
