What we need here is something really innovative to combat the above and provide the ultimate singlespeeding frame solution.
You’re absolutely right. The problem with many singlespeed-specific frames is that they are far too simple. What we need is a really advanced technological solution – perhaps reciprocal eccentric rear hub and bottom bracket controlled by electric motors and governed by an electronic brain that automatically adjusts chainline etc to suit different gearing combinations.
The other, more straightforward solution, that perhaps is more appealing, would be to create a standardised frame with a fixed distance between chainring and cog based on specified diameters for both. Then, rather than change cog size, market a range of chainrings and cogs with different tooth numbers but a standard diameter. That way, the chain length will always be consistent, but you can change gearing simply by swapping rings and cogs.
Another advantage of this for the cash strapped is that you could always grind off a couple of teeth on chainring or cog to raise or lower the gearing. Say you’re running 32:18 and want a higher gear, simply grind a couple of teeth off the cog to give a 32:16 ratio or if you want a lower gear, do the same at the chainring, say 31:16 or 30:16.
Makes a lot of sense to me. It would also reduce the price of SS-specific frames by deleting complex details like sliding drop-outs and track ends.
And if your chain has worn enough to skip, doh, simply fit a new chain. It means it’s worn out anyway.
