I hope they do a carbon version following on from the same value as their hard tail frames. 650b compatible would be nice too if it is possible to make a frame adaptable for both without compromising either.
Edit: this link http://twitpic.com/c23z5h shows the rear triangle arrangement, the bottom bracket arrangement, and the pivot placement. They are ‘cut and paste’ from the original mega, or I’m a Dutchman.
ah thought it was a faux-bar, which didn’t make sense either as Horst patent has expired (?)
so.. what’s it for? shape and coil suggests DH but single pivots were never that great DH ‘cos of braking effects i thought? and a Revelation 32mm. hmm.
just realised the EG29 is a 140mm bike, so this is a beefier AM 29er and they couldn’t find a suitable fork for it yet?
Steep seat angle? Yup. Helps to winch and plummet.
Singlepivot? Yup.
Braking effects? Sam Hill seems to be loving his Nukeproof, which evolved from the Scalp which I helped scribble down. Actually this bike has the same downtube as the Scalp. A bit over built but it’ll let us get the centres signed off.
Travel is 128mm, 440mm chainstays.
Brant how would you describe what this bike is for? First 29er I’ve liked the look of.
It’s what I’d call a trail bike. I’m well aware it’s lack of front mech will cause issues but:-
1) 28/36 low gear is pretty low.
2) I don’t mind walking sometimes.
3) Removing front mech capabilities lets us do other things better.
4) Life is one long compromise.
5) Other bikes are available.
Ta. Lack of front mech not necessarily a problem. What’s a likely build weight without spending silly money? I would definitely prefer beefier forks – not sure what’s available for 29ers though.
Are there any 28t chainsets available for mear mortals who can’t justify XX1?
MRP blingring on a SRAM XO crank works a treat on 29er, although I should say my 29er weighs sub-26lbs. At 32lbs I’m not sure I’d feel the same way on climbs!
