Hi Takisawa2,
When you say 36-32, do you mean a front chainring of either, 36/34/32 ? Or is 32 your rear cassette 11-32???
I will be running an E-Thirteen guide/Bash set-up.
Hi Takisawa2,
Personal innit. I'd not go smaller than 36t, if anything I'd go bigger. Don't run out at the bottom end, and could do with more top end on the road to/from the trails and the odd descent.
It is personal, but the posters did make it clear that you only need a ring bigger than 32t at the front if you're a) riding a lot on tarmac and fire road or b) a real beast of a DH rider.
The point being that for anything off road that's more technical than a fire road, 32t front by 11t rear will be more than big enough for most people (especially on this forum).
if you only ride your bike for a couple of hours at a time and no silly long climbs you should be fine with 32x11-36, serious hills or a proper beast of a ride and I reckon you'll be regretting the lack of a granny, how often you do those sorts of rides will decide whether this is a minor niggle or a major inconvenience.
FTR I ride SS quite a bit so no stranger to gurning up hills in too high a gear, but I have a granny on all my geared bikes.
Personal innit. Some are stronger than others and can get away with taller gearing. Only you know that.
If I found myself regretting the lack of smaller gears then I'd not have stuck with 1x10 (with a 36t ring).
Some are stronger than others and can get away with taller gearing.yeah but a beasting is a beasting, if you do plenty of rides when you're on your arse for the last couple of hours....well I for one would like the easy option to be available
Personal innit.absolutely
Running 36/22 11-34 I found myself using the granny at least a few times on every ride, if not more. When I switched to 32/22 11-34 to solve some poor shifting and chainsuck problems I found I didn't use the granny for the next dozen rides, hence I got rid of it and the shifter/mech and added an N-Gear Jump Stop. I'm no uphill speed demon but I can spin reasonably fast and have fairly big thighs so it works for me!
Try swapping your 36 for a 32 and see how many rides you get through before you resort to the granny, then you'll know if 1x9 or 1x10 is workable for you.
But whilst some may struggle on a certain ride (and be glad of a 32 or a 22) others will be fine!
Do your stop screws on your mech too so you have to stop and adjust to get into it, unless you're very strong willed you'll just bail out into it if it's there, whereas you'd probably just push on with a single ring.
But whilst some may struggle on a certain rideno "certain ride" I just meant going out and destroying yourself immaterial of whether other faster/fitter/slower riders are with you, riding til you can't ride anymore and then riding the 15miles home
But I'm arguing semantics/defining my point, as we both agree the pros/cons of 1x10 are a personal thing.
I'm far from fit but after swapping from a tripple, then to a 22/36 double and now to 1x9 11-34 32, there is not much i can't get up where I ride. And i'm not bothered about spinning out on the road, but its fine for a steady pace. Had to lighten the bike to help compensate, mind but moreover think more about how i ride and use my gears.
Ok think my decision is final then
Does anybody know if my Saint rear derailleur will be fine with 10 speed?
Also, the difference between 1 x 9 and 1 x 10 with the same front chainring, does the 10 give an extra lower gear, or an extra higher?
Thanks
No, you need a 10 speed specific rear mech, or a road flat bar 10 speed shifter.
Potentially either, but generally low. You can get an HG50 9 speed cassette in 12-36 (but they weigh a ton), or various cassettes in 11-34, 10 speed comes in 11-36.
Personal it truly is, but have you considered going 1.5x10?
Leave the granny ring on and chose the 1x10 that looks ideal.
Remove front shifter, cable and Mech.
Granny and bolts = ~30grams.
Use your right heel to kick-down to engage granny and cruise the lung-buster.
Put chain on the larger chainring manually at the top whilst getting breath/eating/drinking.
Too simple?
PaulD
You could cobble together an 11-36 9spd without too much difficulty...
Does a saint mech stretch far enough for a 36t sprocket?
hold on does that mean that
This: Tiagra 10spd flat bar shifter
plus
This: SLX 10spd Cassette
And my current 9spd SLX mech would allow me to run 1 x 10 without needing to buy a new "Proper" 10spd rear mech? or would I need to go buying new jockey wheels?... Might just be easier to go 1 x 9
c,
You can substitute the 12T for an 11T with its specific lockring for a 9-speed Deore based 11-36T 'brick'.
Saint will cover a 36T sprocket.
The Tiagra 10-speed bar shifter will drive the Saint for a 10-speed cassette.
Jockey wheels will be OK with a 9 or 10-sp chain.
So, what about my 1.5x9/10 idea?
PaulD
No chain guide, so the chain will be all over the place.
But you then end up with a jump in the block, right where you don't want it.
hold on does that mean thatThis: Tiagra 10spd flat bar shifter
plus
Correct.
Standard HG61 goes: 12-14-16-18-21-24-28-32-36
switch the 12 for an 11 and you get a 3 tooth step at the tall end, hefty I suppose but then that cassette already has several 3 and 4 tooth steps from the middle to the top the fact is that any 1xn drive train will need to have big steps in the gearing to get that wide range, 10spd doesn't cure this either.
I could be tempted to bastardise an HG61 as it's the absolute cheapest route for me to get an 11-36 cassette, but I can certainly also see it being less than ideal for the type of riding I do and I'd only wind up reverting to 2 x 9 until something a touch broader ranged becomes more widely available...
Not strictly, you always have bigger jumps at the top, but the gaps are much 'nicer' with a 10 speed 11-36 cassette: 11-13-15-17-19-21-24-28-32-36
If you're happy with that jump then a bodge certainly will work.
Well I can't see why you couldn't use a 9spd mech with a 10 speed shifter.
There isn't any 9-36 cassette / hub in production right now. Widest available is 11-36, unless you go custom at £70 per sprocket and get massive 37/38/39/40 tooth dinner plates.
Shimano capreo is 9-26t (9speed) but requires the capreo freehub - this might fit other shimano hubs.. you could by muxing cassettes built a 9-36
though 11-36 should be enough!
Different cable pull, same reason you can't mix SRAM/Shimano. However 10 speed road is the same as 9 speed MTB, so they're cross compatible.
Nah, axle and everything is different, and as the freehub's a different diamter you can't combine with 'normal' sprockets to get a lower gear.
I like what Hope are doing, but I can't help but think the chain will feel horrific on a 9t sprocket.
Well if the hope cassette ever get to maket 9-36 equates to a 400% gearing range where 11-36 is a piffling 327%...
Capreo is intended for HPV/20" folder bikes and is a miniature nightmare for MTB use due to the special freehub body and the fact that you are stuck with the bottom 3 sprockets (9-10-11) theres a company called ICE doing a special 135mm spaced capreo cassette compatible hub* for ~£90 but then you have to buy a Capreo 9-26 cassette (~£55) and then either pull apart some other 9 speed cassettes or order single sprockets to assemble a bigger range one. So i actually winds up costing a small fortune!
so far as I know the best anyone has managed is a cobbled together 9-34t (9speed) apparently, which sound great but isn't really much of a range improvement over 11-36 is it...
*(Shimano don't do a disc hub for capreo, and although I've seen it suggested that a Capreo free hub could be cobbled onto a shimano disc hub, I've not heard or seen any real evidence of it really being done...
Specialized had a test bike using a capreo based 9-34? cassette knocking about over a year ago now (Article still on pinkbike I think) but again that was a custom FH body machined for them by DT....
It's certainly mechanically possible but Shimano themselves clearly are not going to make it easy to get a 9-36t 400% cassette and everything else out there looks like a relatively expensive bodge...
Nope the Hope concept is actually the "Best" way to achieve it, but you still can't buy bloody one.
Sure they'll still be available for a long while - or you can just use 10 speed road stuff!
I'd rather see 11-38 I reckon, really not sure what a 9t would feel like.
I tried resisting the urge to drop to my 24t inner from a 32t middle (11-36 cass) - when I first got my 5 with it's 10 speed gearing. Whilst it was possible for me to ride most stuff around here (morzine, lifts closed), I would only ever be able to do it if I was either one my own, or totally unsociable and ride off the front of the group I was with - the time spent waiting at the top was also spent getting my heart rate back down to normal!
Then I thought to myself - fxxk it, I'll stick with 2x10 thanks. If I lived in Dorking then it might make more sense for 1x10, or if it was an Enduro race bike perhaps... but other than that, I like my knees too much to get drawn into it. The 9-36 hope cassette does look promising though... could drop down to a 30t ring and be done with it.
My patriot on the other hand is 1x9 and only comes out when there's uplifts involved. Then the climbs aren't so long or it's hike a bike territory.
Thing is if you want the same gearing range that a 9-36 would offer but keeping an 11t as the smallest sprocket, you'd have to got up to 44T at other end to achieve the same range on a single cassette...
Effectively that means 2 teeth off the bottom is worth 8 more at the top, literally dinner plate terretory, theres always going to be issues surrounding chain wrap, frictional losses, wear and drive efficiency but you're not actually going to pedal everywhere on that 9T sprocket are you, and TBH I doubt it's actually noticably worse than an 11T
You'll extend the available gearing range, mechs don't need to get any bigger, weights stay about the same (possibly go down a tad) and we're all that little bit closer to 1xn Nirvana, Hurrah!
All we have to do is make one already quite small part a wee bit tinyer...
You must log in to post.
