Viewing 16 posts - 1 through 16 (of 16 total)
  • Oil Rayburn help
  • racing_ralph
    Tonight it started smelling “fumey” and has got steadily worse. When i opened the burner door to investigate i was greeted by more fumes and thick soot! also under the hotplate is sooted up!
    Last week when it was incredibly windy it went out, i did not reset the trip before i re-lit it – is that the problem or more complex than that?
    MrNutt
    hope you’ve been saving mate! Rayburn/Aga fitters/parts ain’t cheap!!
    racing_ralph
    why would i need a fitter – just needs a service – that is a DIY job
    MrNutt
    fitter, engineer, bloke with bag off tools, etc
    usually costs a packet.
    edit: but if you can DIY thats good, when was your chimney last swept?
    racing_ralph
    never to my knowledge
    smiffy
    Which model?
    Test the draw of your chimney by lighting a bit of newspaper and dropping into the hole where the hotplate sat. if the smoke is pulled towards the flue, you’re OK there. Get it swept anyway.
    Look down from the top towards the burners, from what you describe, I suspect you’ll find a great clod of oily soot dislodged by the wind is killing the draw above the burners around the boiler pipes.
    remove the burners and completely de-soot and de-coke, removing and discarding the wicks.
    Brush and vacuum out the whole thing until like new.
    Put back together and light, after leveling the burners of course.
    racing_ralph
    cheers thats what i am doing tonight
    smiffy
    which model?
    racing_ralph
    not a clue – how long do i leave it for oil to come through to the wicks before lighting
    racing_ralph
    chimney is not blocked – pulled quite well so have relit it. If no response in a few hours we are dead!
    MrNutt
    ralph?
    RALPH?!?
    RAAAAAALPH!!!!!
    racing_ralph
    Just looked at it again!! New wicks fitted – now it won’t light Grrrr
    Seems like oil gets trough but cannot sustain the burning if that makes sense.
    It is a 300k BTW
    Junkyard
    i heard something on Radio 4 – where else could you learn this- there has been real problems this year with the oil as it has changed standards/quality /rating (clearly forgot the exact details). This has led to many many issues with oil fired systems including AGA’s.
    I bet if you Google it you will see stuff about it
    Shame cos when they work they are brilliant and when they dont the effing stink.
    racing_ralph
    Thats what i was told also – mmm what to do?
    Junkyard
    Dont think you can do anything contact Aga direct?
    Probably a petition somewhere but in the immediate future not a lot you can do.
    racing_ralph
    how the **** do i light it tho?
The topic ‘Oil Rayburn help’ is closed to new replies.
