Apologies, a bit wordy…
After years of being slightly frustrated by OpenOffice, and then LibreOffice, yesterday I finally bit the bullet and signed up for a Office 365 subscription. I went for one of the packages that include a full Office 13 installation. I downloaded the installer and let it do it’s thing.
When it had said it was done, I tried to open a couple of spreadsheets (by double-clicking directly on them; I noticed that Excel had set itself as the default application) I’d created and had been using in LibreOffice (althought they were saved as .xls/.xlsx). Excel thought about it for a bit and told me it had experienced a problem and would close. Smashing. So, I opened Excel directly, fine. When I browsed to the spreadsheets and tried to open them, it had a problem again and closed.
Exactly the same happened with Word docs.
So, I rebooted to see if that would sort any registry-type confusion. Same result.
I then did the ‘Quick Repair’ option in Add/Remove Programs, rebooted after and tried again. Same result.
So I then did the ‘Full Repair’ option in Add/Remove Programs, rebooted after and tried again. Same result.
Grr.
I suspect that it’s something to do with the format of the files that LibreOffice has created and saved (even though
they’re .doc/.xls/.xlsx). However, I have opened them with no problems on another machine with Office 2010 (and in Sheets on my phone).
My next thought is to uninstall LibreOffice, in case there’s any file-default knicker-twisting going on anywhere. After that I’m a bit stumped.
Any ideas?
