….and did they need a service! Front brake has been sticking on so I completely stripped the caliper and cleaned and polished everything before reassembling with a service kit kindly donated by a gentleman of this parish (sorry – lost your name!) then I tackled the rear brake – yuk! One piston completely seized in and took a lot of pressure from the track pump to blow it out. Caliper in generally ropey condition so cleaned and polished everything and reassembled with the same seals – hope it doesn’t leak!
I don’t think I’ll bother servicing the levers yet – apart from dirt and general oxidation caused by trail filth the actual internals and seals of the calipers were in good shape, so I’m hoping the levers will be OK internally.
Nice and sunny out in the utility room, which is better than the freezing cold garage. I need the light and when I drop small bits on the floor it’s easy to find them.
Back to work tomorrow.
