re above post re different steerer lengths quoted – lifted from On one website
Rock Shox Reba Team 100 Black 2009 With Pushloc & Manual
Steerer is cut to 210mm and fitted with a star fangled nut
The perfect Cross Country fork, the Reba Team puts together light weight, stiffness, and consistency to make it one of the top suspension products on the market.
Cross Country riding is an adventure. It is getting outdoors and becoming part of landscape rather than just looking in from the outside. Powering your bike along an epic single track in the mountains or just cruising your local trails, cross country is a lifestyle you can only understand by doing it. Todd Wells: Team GT Bikes
• Travel – 100mm
• Travel Adjust – All Travel
• Weight* – 1610g (3.55lbs) to 1814g (4.0lbs)
• Spring – Dual Air
• Spring Adjust – Air pressure via dual Schrader valves
• Damping – BlackBox Motion Control
• Damping Adjust – External rebound, low speed compression to 'Lock' with external Floodgate
• Lowers – Magnesium, post mount disc brake
• Crown – Forged, hollow AL66 TV aluminium
• Steerer Tube – Aluminium 1.1/8 (Cut to 252mm – SFN fitted)
• Upper Tubes – 32mm, 7000 series straight wall aluminium, low friction anodized
• Suggested Rear – Shox Monarch / Ario
• Max. Recommended Rotor Size – 210 mm
