Viewing 9 posts - 1 through 9 (of 9 total)
  • oem forks
  • lord
    oem forks any different ? thanks
    nickc
    Colours, sometimes a bit more weight, sometimes adjustable features not present.
    gingerflash
    occasionally a steel steerer instead of aluminium, sometimes a bit less external adjustability. Most are the same these days I think. I think some really cheap oem forks might be different though.
    MrNutt
    yes, usually less adjustment, not necessarily heavier.
    james
    Which ones?
    If they are rockshox, the OEM ones have a different number (eg 409, 335, 327, 289). If you go on the website you can compare models to see what the differences are
    GW
    what a wonderfully vague question, the wonderfully vague answer is “sometimes” 😉
    lord
    426 revelations silver
    james
    426 revs are normal (non OEM) stock
    409s are the OEM ones (the only difference being the floodgate (how lock out the lock out is when engaged) adjuster requires an allen key)
    lord
    cheers chaps.
The topic ‘oem forks’ is closed to new replies.
