I’ve having an odd issue with my SRAM X9 rear shifter.
When shifting down, i.e. pulling on the cable all is good.
However, when I shift up, i.e. release tension from the cable, the cable jumps over the thing it should be being wrapped round, and a couple of gears are dropped, and it isn’t possible to shift back down.
I can sort it by simply shifting all the way up to top gear, or until the cable is back where is should be, and then shifting down again.
