I agree with cheese.
I had a set of Marathon SLs which could be locked down for climbing, too about 4″ off the front end, made it better for me.
However, every rider will be different and if lowering the front end has upset your position, maybe making you lean further forward, you may not be able to produce the same power for the same perceived effort, therefore making it ‘harder’.
TBH on the kind of climbs where you are likely to want to drop the front end you are unlikely to be going quickly enough for the slight improvements in aerodynamics to be noticable, and if you are not honking out of the saddle and bouncing the forks up and down the lesser amount of travel probably won’t be noticed either, so it must be down to position and power output.
