the fronts decent bit easy to crease though,
i tried the rear on my xc bike with a 30.9 seatpost
it was rubbish,poor fit, moves when knocked,
no mater how tight the strap is.
then i put it on the commute an shops mtb which has a 26.6 seatpost,
it fits tight on that small post with the buckle in the middle of the strap pulled as tight as possible, and it didn’t move if i whacked it,
i whacked it about a fair bit an quite hard,
i was worried if i hit it any harder it would brake it,
but it stayed in the middle
its only going on a bike that will be going mostly in straight lines on flat roads, running 26x 2.0 slick tyres,so a lot less flicked up then muddy knoblys
i should be ok 😯 fingers crossed :?.
im running it on the middle hole setting so its pointing up a bit,
but tbh its a pretty ugly rear fender in any of the 3 postions.
ile see how it gets on commuting an shopping an even take it on some flat xc
an see if it stays put 😯
if its rubbish at that i suppose if i pierced some holes in it i could use it as a gut fender on a 29ner
