I was brewing last night in me cellar, with a 40L boiler plugged into an extension reel. After a bit the power cut out and the extension socket was really hot (it’s got a thermal reset button on it if that is relevant).
So I had to move my boiler to a sub-optimal spot and plug it into the mains, and that worked fine as far as the power went.
Why is the extension reel not up to the job – is it something to do with its fuse not being big enough? Ideally I would like to brew outside, but it would be good to know what sort of extension cable I would need to buy to power the boiler. I guess the boiler must use a lot of power relative to most appliances?
Thanks for any advice, don’t really know the ins and outs of fuses, power etc.
