The weight savings for Ti versus steel springs are not consistent, even between springs of the same dimension. Have a look at the weights section on Sicklines under the suspension/rear springs part and you’ll see what I mean.
Personally, having weighed the two springs I have in my garage – a Nukeproof Ti and a Cane Creek Steel, both being identical in dimension (450lbs/inch 2.25″ stroke) the weight saving is about 280g.
You will get less saving if you end up going for a Ti spring that has a longer stroke than you need. As long as the force rating is the same, it doesn’t matter whether you put a 3″ stroke spring on a 2.25″ stroke damper – the force rating determines the rate of compression (of course the longer spring might not actually fit).
To maximise the saving, go for a spring with the right stroke length, that way you’re not carrying around extra coils you don’t need.
As for whether even 150g of weight saving is worth it, that’s a matter of personal choice. 150g here and 150g there pretty soon adds up to being material so as long as you’re pockets are deep enough, there is a lot to be gained (or rather lost) in the weight of your bike.
