So I bought a wheel from herewhich has a “novatec/Superstar Switch” hub in. Came 142×12 which is great but my frame needs old-fashioned 135QR so I managed to find one also on here.
Then I discover that there’s a chance these two parts are not in fact compatible. Maybe.
Putting in the QR axle results in this:
There’s a rather large looking unsealed and exposed area (the silver bit) between the XD driver and the axle, looks like dirt could get past the cassette and into the bearings that way. Also until I put the centerlock lock ring in the axle has about 5mm of side to side play.
Does this sound right and I should stop worrying? Or is this the wrong axle? Should the XD driver have a special end cap? Why can’t people just put a model number somewhere on any of this?
(in fairness the old 142×12 axle has 519-03082500001 stamped on it, and the XD driver has HEC-T02100200003-B, but google has no idea what these are)
I’m taking the Superstar name as provisional, it’s most likely a Novatec hub but has no branding on so may or may not be one of the models that Superstar resell.
Hey Ross, it was definitely a Switch axle, so unless they redesigned the hubs since I got them I don’t know why it wouldn’t fit in yours? Pretty sure there weren’t any other washers or spacers with it but will check my parts box and let you know!
I suspect they’ve changed how they look over the time, as there’s now the Switch, Switch Evo, and Switch Ultra. My suspicion is that the hub I have is a Novatec but isn’t one of the models that Superstar resold as a Switch.
Posted 6 years ago
Viewing 6 posts - 1 through 6 (of 6 total)
The topic ‘Novatec/Superstar hub axle woes’ is closed to new replies.
