If the Novatech hubs you have are similar to the Superstar Switch hubs. Then its pretty much the same process as the video just skip part where he takes the freehub off.
Either pull the end caps off if you have 20mm or 15mm through axle, or if using QR use cone spanner to screw the caps out. The QR axle might need a tap with with a hammer to slide out.
Inside the hub you will see there is a metal shelve that sits between the two bearings preventing good access to the inner bearing race. In the video you can see pop out at 1.59. In my Superstar hubs there was a 1mm gap between the sleeve and the bearings allowing a small screw driver or drift to get enough purchase to hammer the bearing out. Once one side is out it will allow better access to the remaining bearing making it much easier.
Then push the new bearings back in either with threaded rods and washers or a proper tool.
