Leaving a cold bridge then.
a small one though. you can get high density plaster board as acoustic insulation. I'd be inclined to bang up a load of celotex/ kingspan then HD plaster board on top.
Insulation is dealt with differently in Europe because of the different climate and construction methods.
Any area not insulated is going perform poorly. This will have the effect of reducing the performance of insulated areas next to it and (simply put) it will 'draw heat' out of it quickly.
As I have said, my choice in this instance would be to insulate the 'non room' side using insulated plasterboard.
No DS it won't, but cold bridging causes moisture and this is best avoided! Going back to our man, not sure I understand re the window. Surely all you would be doing is making the window reveals deeper? You wouldn't have to replace those reveals with insulated if that's the problem. Just abut the current reveal, introduce a skim bead and re skim the reveals when doing the main wall. Also I'm not sure how the door is working, are you saying it's in a 2ft reveal??? If so how thick are the bloody house Walls
@wwaswas - it's already painted. It's also in good nick, so isn't going to be touched (been inspected by a pro).
@mk1fan/don simon - fair enough, so the insulation would be less effective. Any idea what the percentages are?
@wrightyson - I'll do a better drawing in a bit.
You're over thinking the situation.
OK - new drawings.
First is a plan view of non-room, showing reveal for garage door.
Second is end on view (elevation?) of non-room end wall with window. The window reveal is straight up to wall adjoining garage. the garage window on the other side of the wall is effectively a continuation of the window. Yes, it is odd, but this is a one-off house designed by the bloke who built it.
What that means is that any insulation on the non-room side of the garage wall would effectively overlap the window frame on that side, and may overlap the glass itself.
Have I made any sense?!!
Probably. Feels like neither option is ideal. Just trying to work out which is better for the circs of the house.
Have I missed something here or is there a valid reason for no mention of cavity wall insulation?
I'm not convinced there's a cavity - unless I'm much mistaken, it's a single skin block wall.
How will that affect the change of use with regard to building regs and planning permission?
Dunno. Not sought BR consent yet to knock thru.
Oh.
I can now see your plight! Have you thought about becoming an architect btw?
So you're only real option is to insulate the garage side then. Just as a note is the non room wall currently plastered??
Fair to say I have stretched my artistic skills quite a way to draw these out, so no architectural retraining for me....
Non-room is a real room - used to be a bedroom before previous owners (not the original builders of the house) put the door into the garage. It's just chillier in there than the living room, and gets noise - admittedly not a lot - via the garage and side window from the lane out the front of the house.
Actually, this week we had more noise out the back of the house as the farmers were ploughing the field in the dark. Lights on the John Deeres make troute's efforts look a bit wimpy..!
OK, so we seem to be veering to insulating (as best as I can given the confines of the garage ceiling) the garage side of the wall.
Cheers all..!
Showed this thread to one of the technical guys from SRS and he says it’s important to not confuse acoustic insulation with thermal insulation. This is his post; Something that will stop sound will be very heavy, and isolated from the wall behind. How about battening out the wall with 2” battens and fitting kingspan or celotex thermal insulation between the battens. After that use resilient bars to isolate the new dry-lining from the wall behind, and then use two layers of heavy plasterboard or something a bit esoteric like Maxiboard (http://www.youtube.com/watch?v=-sPbPjKW8LM) to create the skin. You can put some mineral wool between the res bars too, it helps marginally but don’t lose any sleep about it if it gets forgotten and don’t pack it in too tight.
Cavity insulation, magic mineral wool, nanovacuums, eggboxes, polystyrene do f*** all!
Oh, and for the windows, secondary glazing that’s at least 2” from the existing glass and ideally a different thickness is the way to make windows better.
Cheers Mr Sparkle - that looks proper techy. Will have to read several times over later..!
I did have a niggling feeling that the window was in an 'odd' position.
Celotex (or similar) glued and screwed to the garage side of the wall can be carried up to and abutting the ceiling without interfering with it.
You may also consider using a thermal wallpaper - such as Wallrock - on the warm side. A similar product is called Sempatap but it is a lot thicker (10mm as opposed to 3mm Wallrock) so may not work well with the window reveal.
For sound insulation construct a timber stud wall in the garage (20mm away from the wall) with mineral wool insulation and two layers of 15mm plasterboard. You can tie the head plate back to the wall rather than to the ceiling.
If you tape over the Celotex joints with the ali tape then you won't need to worry about water vapour/condensation.
Still trying to head my head around 90% insulation will produce a cold bridge question. If there isn't a cold bridge before insulating and no evidence of condensation, why is cold bridging suddenly going to appear when insulation is applied to some but not all the surface? And why isn't it a problem with windows?
I can understand the idea of cold bridging through a solid medium like brick ties or a metal window frame, I just don't understand how the characteristics of the wall can change...
If the air can not circulate it will offer you good insulation, I think this is why they use it in double glazing.
donsimon - all things relative, the whole darn wall is a 'cold bridge' at present, and all the wall is cool, so evens out areas of condensation. Make most of the wall newly insulated, and the temperature of that area of wall compared to the uninsulated bit means you will get more condensation on the cold/uninsulated bit. Like you do round most windows. In a perfect world you would avoid this, but it is not a deal breaker / mahooosive issue unless you are heading towards seriously low energy build...
You must log in to post.
