Yes, there are still people non-1x :(. I’ve got 2×10 (SLX shifters, Deore FD and XT RD) setup. The bike is only few months old.
After messing a bit too much with the gears, I managed to get the front derailleur work pretty well, shifting back and forth. However, I have rubbing in either extreme end: innermost or outermost cogs (as in, smallest front and largest rear and vice versa).
Both limit screws allow enough movement in either side. If I tighten the cable more by adjusting the barrel in the shifter, then it rubs the chain when on the smaller cog. If I slacken it, then it either does not move enough to shift or rubs terribly on the larger cog.
The chain seems to be parallel to the shifter cage and there’s a 3~4mm vertical gap between the cage and outer cog.
HELP?!
