just need to get either a reducer lower cup, reducer crown or an adapter to use a 1.5″ crown race. The reducer lower cup is the least preferential option as you need to change the whole lower cup if you get a tapered fork.
Lots of headsets out there – just choose the type you need – ie low stack semi integrated or external lower cup.
Only problem you can have is on frames with very short head tubes as some taper forks taper too gradually so the headset won’t pre-load properly. This is normally a case on headtubes lower than 100mm. – but that is tapered forks not straight.
The hope adapter is one of the easiest options as it just converts your fork to tapered (but without the benefits). Some headsets come with both crown races though.
