Viewing 9 posts - 1 through 9 (of 9 total)
  • Non-Shadow XTR Rear Mech on SC Superlight….should I?
  • megastream
    Just need to get the rear mech and my SC Superlight build is complete 8)
    Decision now is if I should go 'standard' XTR rear mech or opt for the narrower profile shadow M972 model.
    I've been riding years and never had a problem hitting the rear mech on anything, what are people's thoughts on shadow mechs? Should I bother?
    Onzadog
    I can't help thinking that the narrower shoulder will increase the slop that develops in that main pivot. As this is how my mechs eventually die, I tend to avoid shadow kit.
    megastream
    Thanks, any other opinions before I put my order through…..
    Daffy
    Do you normally use rapid rise?
    cynic-al
    Aren't shadows a bit notorious for bending/breaking easily?
    On any bike, not just Superlights?
    Oh and Onzadog, there is no upper pivot?
    megastream
    Daffy – Member
    No, I'm going to stick with normal action on this bike.
    gingerflash
    while shadows stick out from the wheel a bit less, the longer cage means they're closer to the ground and just as likely to get hit. I think they're a bit less precise in the shifting as normal mechs.
    steve_b77
    My XT shadow mech is very nice, shifts well and is really tucked away under the chainstay.
    Feels better than the X7 it replaced if thats any help
    Onzadog
    I know the bolt into the frame isn't a pivot but I thought the large torx head beneath it was (and was narrower than the main pivot on a normal mech) but I don't run one so will happily learn from anyone who does.
The topic ‘Non-Shadow XTR Rear Mech on SC Superlight….should I?’ is closed to new replies.
