• This topic has 19 replies, 17 voices, and was last updated 6 years ago by cokie.
Viewing 20 posts - 1 through 20 (of 20 total)
  • non boost 29/27.5+ frame that isn't…
  • rOcKeTdOg
    one of these as i’ve had them and sold them on
    solaris
    big wig
    so 135 or 142mm rear end, 29×2.4/27.5×2.8 compatible minimum, able to accommodate a 130mm 29er fork. 67-65degree head angle. can be any material.
    letmetalktomark
    Pipedream Skookum
    Kinesis FF29
    Stanton Sherpa MK1
    chakaping
    Hardtail?
    Stan_Dingup
    Pace RC127+ / RC129?
    rOcKeTdOg
    chakaping – Member
    Hardtail?
    yep
    thisisnotaspoon
    Last Fastforward.
    Bolt
    Pipedream sirius 4g
    Bolt
    chakaping
    Can’t think of any then, sorry!
    bungalistic
    Have you got all the spare parts you want to hang off it?
    If not Sonder do a Transmitter alloy with 650b+ wheels for £449.
    NormalMan
    Karate Monkey?
    frood
    last fast forward is good.
    cframe
    Kona Unit?
    I picked one up earlier in the year and while I’ve not had time to ride it much it seems like a lot of fun so far
    Andy
    What was it about the Solaris and bigwig you didnt like?
    shortbread_fanylion
    You’ll struggle to get those tyres in a mk1 Sherpa – mk2 would be fine though.
    theboyneeds
    Pinnacle Ramin 3+
    metalheart
    My new gen Sherpa has 3.0″ Trail Boss on the back with a 142 bolt through.
    Not sure it’s 130mm compatible or 65-67 though…
    But I would advise a boost chainset if you want to use the bottom two gears… 😳
    sheck
    Singular Buzzard…. a bit short, so need to size up, which inhibits long dropper use, but otherwise a lot of fun, with masses of rear tyre clearance
    sv
    New Stooge? Not sure if it ticks all those boxes but they are great frames.
    rOcKeTdOg
    sv – Member
    nice but brand new frame without stealth dropper compatibility?
    cokie
    Olsen Enduro or XC carbon frame.
    Made in the UK with semi-customizable geometry. http://olsenbicycles.com/
    £1,000 on Indigogo at the moment..
The topic ‘non boost 29/27.5+ frame that isn't…’ is closed to new replies.
