I’m a bit quicker than I have been on the local downhill, but still dragging the front brake most of the time. The last two times I was out riding, I noticed that the front brake lever became a bit more resistant. Releasing the brake for a couple of seconds meant that the lever was easy to squeeze again.
Once upon a time, I had both my front and back hydraulic disk brakes fail (Hayes Sole, I think) going round a reservoir. The resulting slow speed off wasn’t serious, but highlights to me that I want to be sure the same doesn’t happen at greater speed.
Why do you think the brake lever became ‘pumped up’? Is it just a manageable build up of heat, or is some maintenance required? I’ve seen something about the hydraulic oil absorbing water, but I didn’t think water would be able to get into the system.
