Viewing 40 posts - 121 through 160 (of 181 total)
  • No helmet. The urge was strong.
  • TandemJeremy
    Bermbandit – my point is that they use research from such people as the TRL – not that TRL use it.
    All cyclehelmets.org is is a is evidence collated and discussed. So you have the links to the original research that you can follow and then read the discussions.
    Its a lot of high quality peer reviewed research linked to on that site. Take your pinch of salt into the discussions on the site of course- it is need as with all such.
    glenp
    In that case hilldodger you just weren't being sufficiently realistic when you were watching the riding/accident. We live and learn, and there are always new occurrences that inform, but accidents mountain biking are largely predictable. Not that they will always happen, but the likelihood in certain circumstances is much higher. The last descent of the day is a classic one – so I would never lead a group into the final singletrack of the day with resting for a minute and having a quick composure check/brain reset. Everyone in our group is always wearing a helmet, but it would be negligent to fail to do the active safety that helps avoid the accident in the first place.
    hilldodger
    TandemJeremy – Member
    Hilldodger – you are wrong . You clearly do not understand what a risk assessment is – still – don't let that stop you attacking me will you.
    One can apply the principles of risk assessment to any activity – and cycling is not different.
    TJ, you are wrong – I am perfectly aware of what a risk assessment comprises and have written more than I care to recall 😛
    I see now you're watering down your claim that you've 'performed a risk assessment' to 'you've applied the principles of a risk assessment' that's much better 😉
    hilldodger
    Drac – Member
    Hilldodger how did you learn that touching fire can burn you?
    The hard way 😕
    Did you have a full hse report on it when you were a kid?
    Nope, neither did we have cycle helmets back in those days 😉
    hilldodger
    glenp – Member
    Yes, you're right – maybe it's that the 'silly' accidents are more memorable.
    Anyway, last 'jump of the day' is a good example of predictable risk, any other typical 'it's all going to end in tears' situations have you come across ?
    TandemJeremy
    Hilldodger – why do you distort and misquote what I say? you are an ignorant low level troll – You got me to bite once again. Well done. Feel better now?
    funkynick
    My god… how did you manage to survive?
    ;o)
    It's gotta be a miracle!
    AndyRT
    In 1994 I had a bad stack. I broke my wrist, tore ligaments in my shoulder, and broke 3 ribs. I also crushed my helmet on one side, and could only see in red and white for about 5mins, after being unconscious for a minute or so, according to my riding partner. I never ride without a helmet. I would have probably died if I hadn't been wearing one.
    Never ridden a Scott since, either.
    If I see a numpty riding without a helmet (with the exception of riders going uphill, with helmet strapped on them somewhere) I just assume the Darwin principle will take effect.
    Stay safe, ride on your limit and wear protection for our dangerous sport.
    Remember, you might not bounce……
    The hard way
    Precisely. So now you take care and asses the risk.
    Same as when you biking you may find away around a certain section to avoid falling off, we do risk assessments everyday have done since you pretty much could crawl. We're not talking full on H&S risk assessments that are a complete pain just a common sense learnt the hard way assessment.
    Waderider
    You guys are over complicating things (and why not stop bitching at each other). Live to cycle, not post on the net. Let the scientists deal with such issues via the medium of peer reviewed research, saves us the debate:
    Author
    Attewell, 2001
    Study quality and conclusions
    Selection critieria and statistical techniques clearly explained.
    Results provide clear evidence of helmet benefits.
    Helmets reduce risk of head, brain, facial injury, and death.
    Helmet use should be encouraged for all riders.
    Author
    Kelsch, 1996
    Small series hospitalized cyclists.
    Bicycle helmets reduced the incidence and severity of head injuries.
    Author
    Finvers, 1996
    Strong prospective effect of helmets for serious head injuries.
    Protective effect of helmet underestimated due to exclusion of ICU cases. None of the ICU cases wore helmets.
    Tertiary care study, not population based.
    Author
    Acton, 1996
    Oral maxillofacial injuries frequent.
    Design modification helmets need such as a lightweight chin protector.
    Author
    Thompson et al., 1996
    Bicycle helmets are effective for all bicyclists regardless of age and regardless of motor vehicle involvement in the crash.
    Largest prospective case-control study of helmet effectiveness to date. 88% response rate.
    Author
    Helmets protect against upper face and middle face injuries.
    Use of two control groups thought to "bracket" the true effect of helmets on risk of facial injury.
    General bicycle helmets with chin protection should be developed.
    Author
    Maimaris et al., 1994
    Good case ascertainment.
    Helmet use significantly reduces the risk of sustaining a head injury, regardless of type of bicycle accident.
    Some evidence refuting claims that helmet users are either more cautious or take more risks than non-users (8.1% head injury among non-helmeted bicyclists; 9.2% among non-owners; 3.5% among helmet users).
    Author
    Thomas et al., 1994
    Helmet use significantly reduces the risk of upper head injury and loss of consciousness in a bicycle crash.
    Helmet use does not signifiacntly reduce the crude risk of facial injury (no adjusted OR could be calculated from data given).
    Who'd have thought all these scientists could be wrong?
    BermBandit
    Apologies, misunderstood your point, and it does say on the website that they seek to advise and inform official bodies.
    Regardless, having read through it, I do feel that there is a strong anti helmet bias, which is not representative of my admittedly anecdotal experience. For example, I do personally know of people who have died or been seriously injured cycling whilst not wearing a helmet. I know of none who have had the same whilst wearing one.
    As previously stated, its impossible to collate or research why an outcome has not occurred, so no bad outcome = no research, which is why the supporting evidence for helmet wear is not easy to provide. It is however perfectly possible, if anyone bothers to collate information on outcomes when things do happen. I happen to know about what has happened in my locality, and generally, head ground interface without protection has a high bad outcome potential.
    Personally, I do beleive that you will find that cycle accidents are not well researched post event, and statistically it seems to get washed over.
    nedrapier
    glenp: yes.
    drac and TJ: sorry, bit subtle.
    TandemJeremy
    cyclehelmets.org is a useful resource but it clearly requires a healthy scepticism.
    Personally, I do believe that you will find that cycle accidents are not well researched post event.
    Inddeed – all a the research on both sides is very poor.
    Waderiders post has some of this poor reaearch. The after the fact studies of hospital admissions that he refers to all share one serious flaw – it a "self selecting sample". It only considers cyclists that crash and end up in hospital. This means this type of survey will always exaggerate the effectiveness of helmets
    I could easily produce a similar list of research that shows helmets to be of little benefit.
    hilldodger
    TJ, calling me ignorant is a personal attack – that's surely not in the 'big TJ book of excellence'
    As for trolling, well I do get a certain amount of humourous glee from outing internet pedants like you – one minute it's all "TJ and the zen like walk away persona" next minute you're blasting away with both barrels calling people ignorant trolls.
    nedrapier
    Helmet evangelists: do you wear the best possible head protection available – i.e. full face motorcycle helmets?
    If you don’t, why don't you?
    Is it because you’ve used the principles of risk assessment to decide that the level of protection is inappropriate to the level of risk from cycling?
    Did you conclude that this extra protection was worth sacrificing for the benefits of more venting and lighter weight?
    Dales_rider
    I have done my own personal research on Helmet wearing.
    I never use to wear one for about 40 years, started riding off road and realised I came off more than on the road so after a few near misses took to wearing a helmet off road.
    Occasionaly rode my road bike without a helmet until one morning 7 years ago, as a last minute thought I put it on for a ride.
    Lesson 1
    A car hit me from the side [just pulled out] I woke up with the police ambulance in attendance. Needless to say a Met helmet [Tested to Snell] was totaly destroyed.
    Lesson 2
    Riding out with a bunch on the road and some kind soul held a gate [on a gated road] open for us, I was on the outside at the front and when he let it swing closed it neatly dropped me on the road head first. Out cold for 20 seconds or so. Destroyed another helmet again a Met.
    Those 2 occasions have convinced me that to not wear a helmet where there are objective dangers is foolish.
    Whan the dangers are subjective I often dont bother wearing a helmet, this also applies to when I'm climbing.
    BermBandit
    Daft argument frankly ned. Different circumstances and issues, for example speed, and besides in my risk assessment I include heat exhaustion so venting seems sensible to me. However to quote the old Bell Helmet ad if you are saying $5 head? get a $5 dollar helmet, then yes, I do get the best piece of equipment I can manage for what I do. Thanks for asking.
    _tom_
    I've fell off a lot in the past month or so. None of the times has my head come (that) close to hitting the floor. It's my knees and elbows that take all the pain. Both elbows and one knee are currently a bit ripped up. Still wear the helmet on anything that involves going fast down loose or bumpy stuff though, becuase you never know!
    nedrapier
    No problem, BB, thanks for calling me daft, then agreeing with me.
    so you sacrifice protection for weight and venting where appropriate? xc ride, xc helmet? DH day, DH helmet? MX day, MX helmet?
    I never mentioned cost.
    andy_hamgreen
    is there an internet pedant offenders list ?
    just wondering….
    nedrapier
    I think it might be the list of contributors to this thread!
    I enjoyed it more on the first page, when it was all about people enjoying themselves. I was glad to see how long it went on before it descended into the usual arguments. And disappointed in myself that I joined in!
    BermBandit
    Read the post.
    I didn't, I called your argument daft. Perfectly possible for a very sensible person to deploy a daft argument
    And your point is ?
    funkynick
    BB… so you do make an assessment of the risk then, it just happens to be different from other peoples assessment. Life would be so dull if we all agreed though.
    Now, that wasn't so difficult was it?
    :o)
    nedrapier
    uurrr…
    I haven't made a point yet, just asked a question. And I don't think it was a daft one.
    The helmet-in-all-circumstances types always suggest that because you can't tell when an accident will happen, and what sort of accident it will be, you should always wear a helmet. You can't risk assess head injuries out of mountain biking, so you should always wear a helmet.
    But in buying a helmet, you are making that risk assessment: "I ride a lot in summer, and not that fast, so I'll be OK with this uber vented xc lid with no chin guard"
    Unless you wear the highest protection helmet you can find (hands up if you do?), you've made a risk assessment about your likehood of injury and giving up some protection for some comfort.
    That's not stupid, deluded, irrational or selfish. It's a decision, your decision, and you went through the same mental steps to get there as someone who decides to give up a little more protection for a little more comfort.
    jam-bo
    the other night i managed to take my helmet off, hook it on the stem, get my phone out of my pocket, take a photo, put the phone back in my pocket all whilst grinding up a long boring road climb. at the top I managed to put it back on, and carry on riding.
    crazy huh. i could have died….
    BermBandit
    Did I ever say otherwise? All I said was I envy the zenlike ability to foresee a stack. Which in fact goes back to my previous point that nobody goes out on a ride having decided that today is the day for a stack. Its an unforeseen event.
    I think you did, it went like this
    and I asked
    And your point is ?
    Simply because I didn't understand why you would make that statement, or indeed what its relevance to the discussion was.
    nedrapier
    You introduced the element of cost that had nothing to do with what I had been saying.
    nedrapier
    and unless you wear the highest rated MX lid available, you have used you r own ability, zen like or not, to foresee the types of falls you're likely to encounter and chosen your lid accordingly. Same as everyone else, even those whove chosen a not-a-helmet helmet.
    BermBandit
    If quoting a 1960's helmet advert to illustrate a point is mentioning cost then you've got me. The point being that I buy the best helmet I can for the purpose I want it for. Sorry if that wasn't clear for you.
    And your point is ?
    TandemJeremy
    Of course its an unforsen event – but what is important also is how likely is the crash?
    Its the ability to decide the level of risk and make rational decisions. Cycling is generally safe but Some forms of cycling carry more risk than others. We all make decisions about what level of risk is acceptable. Riding a WC DH run helmetless seems rather stupid – but full on DH gear on a canal towpath seems rather OTT. So inbetween those two extremes we all make decisions about what is a sensible level of protection for that ride.
    When I am pootling along local easy paths then I know that the risk of having a serious head injury that would be prevented by a helmet are so low that I am prepared to accept it.
    nedrapier
    And your point is ?
    I think that's it, actually. Can we stop now?
    rootes1
    i wear a helmet as a safety device for others as it stops glare from my slaphead dazzling oncoming road users…
    BermBandit
    Actually don't think I've ever disagreed with that TJ. My beef is this nonsense regarding helmets don't reduce the risk of head damage, cause injuries etc etc. Not for me to tell you what to do, except insomuch as not really wanting to ride with helmetless folks.
    I would say here and now though, that I've never once foreseen any of the numerous stacks that I've had over 40 years or so of cycling. So on balance I wear a lid every time I ride a bike. Been knocked down on the road 4 times, off-road I've broken numerous ribs, collar bones on several occasions, broken my wrist once and assorted other less serious events, but never suffered any serious head injury despite writing off 3 helmets to date.
    TandemJeremy
    Berm Bandit – Member
    Trouble is – that is not nonsense either. It s different point but linked. Helmets provide far less protection than many folk think and in some cases they can make injury worse. How big the "some" is is debatable but the effect is proven to be there. Up to 30% in one piece of research (TRL)
    GW
    Reading these threads makes me wonder just how frequently are people falling off?
    I crash a lot, and have done for many many years but while riding XC I'd be unlucky to have a proper crash more than about once every 6 months, on the Road it's almost never, jumping again almost never (I know how/when to bail, but wouldn't call that a crash), riding DH I'd expect to crash almost every time I ride a proper DH track (or I wouldn't be pushing myself at all).
    Crashing/bailing is a skill that needs to be used to stay good at. I'd say on average most competitors racing DH at Glencoe last weekend crashed way more times than they rode the chairlift up and most would be expecting to whereas most people on here probably find crashing a complete surprise and don't even understand why it happened.
    i ride a bike almost every day without a helmet
    glenp
    Racing is a different matter. For normal trail riding for enjoyment, even if you like to ride fairly fast, I wouldn't want to be crashing at all. Having said that I have lost the front twice in the last few years (nothing serious, wet grass etc), plus I've had a prat fall whilst mucking about in the car park. And that's it for as long as I can remember. Certainly don't know when the last time I went over the front was. Years and years ago. However, I don't mind slowing down to go fast, if you know what I mean.
    al_f
    As someone with "scientific training" you should know that's irrelevant if the question you're asking is "do helmets reduce the severity of injury in cyclists hospitalised after accidents where they hit their head", which appears to be the question most of those papers were asking. Also, you could just as easily argue that it underestimates helmet effectiveness because maybe a lot of people who land on their heads wearing a helmet don't need to go to hospital at all.
    Anyway, still waiting for the list of references supporting your argument. Over to you…
    TandemJeremy
    ALF – go read the cyclehelmets.org stuff. I am not saying its all true but some thought provoking stuff.
    a critique of the cochrane review This discusses the limititions of the sort of research that relies on after the event hospital admissions.
    Plenty of references to follow if you are intested
    http://www.cyclehelmets.org/1146.html
    Aninteresting paper http://www.cyclehelmets.org/1149.html
    GW
    Glen – I haven't raced in over 5 years. Your description of how you ride sound makes you sound like a right mincer TBH.
    BermBandit
    That the same cyclehelmets.org you described as
    🙂 Cheap shot I appreciate, but couldn't resist it.
The topic ‘No helmet. The urge was strong.’ is closed to new replies.
