Hmm, mostly right, but not convinced by the bit about fast smart chargers. I have a homemade fast charger which uses a microncontroller I’ve programmed – I’m using a cutoff algorithm in that which is supposedly suitable for NiCad (-ve delta V), but it works fine with NiMH. Supposedly with NiCad the voltage drops once they are fully charged, whilst with NiMH the voltage stays constant, so you detect the fully charged state differently. In my experience (I’ve done quite a bit of testing of this) the voltage of NiMH also decreases when fully charged, and this is a more reliable way to detect end of charge than detecting constant voltage, hence why I’m still using that. You get a slight overcharge, which will slightly reduce the life compared to an earlier cutoff, but it’s not a significant difference.
