So the new Slash has a low and high position that is switched by effectively shortening seatstay link between the chainstay and main pivot. But when I look at them they just don’t make sense..
So according to Trek they all frame sizes have the same bb height in all sizes for the relevant low or high mode. All frame sizes also have the same head angle in the relevant mode. All frames sizes have the same CS for their relative mode.
However as far as I can work out some of these numbers are mutually exclusive. For example if you drop the BB to the same height in all sizes then a size large which has a longer front triangle would have a smaller change in head angle than a size small which has a shorter front triangle.
Other things don’t make sense such as the change in reach. According to trek there is a 14mm decrease in reach when going from high to low in size large. Yet in a size XL the decrease is only 6mm despite having a longer headtube which in theory mean the reach would actually be decreased more than a large.
