I love the idea but wasn’t a big driver in moving to press fit BB’s the cost saving to frame manufacturers? This will not deal with that.
Once manufacturers see that the cost saving of producing press fit frames is outweighed by the reduction in revenue, then there will be change.
*cough* *ahem*
Some brands never thought any saving or new-stuff sales benefits were worth the hard-to-avoid hassle for the owner or the brand further down the line, or thought the pitch for 30mm axles and BB/PF30 was credible anyway. Not just the bikes I spec but a few others, a minority though. Not being able to fit 30mm cranks has been seen as a negative by some but the ‘advantages’ of 30mm + PF/BB30 aren’t worth the fact it’s often a flawed standard in use. TBH I don’t think the assembly savings (whatever they are – minimal I suspect) were the main driver, more about BB shell size, issues with threaded cups in carbon bikes, wanting a lighter frame spec, having new stuff to talk about, etc.
This new format looks good, will check the dimensions and combatibility before getting excited by it, initially it seems a good idea. There’s not much need for anything bigger than BSA shells on anything but carbon frames though, maybe some heavily OS Ti or Al but not many, threaded inserts / BB cup tool torque on carbon frames is another potentially problematic matter in itself.
My next bike, a steel custom (theoretical) will be threaded BSA unless this allows both larger bearings (a 24mm axle + external cup in a 47mm ID shell combo) as well as the same bearing spacing as BSA HT2 cups – can’t see how if you want to use 2 or 3x MTB chainsets. A bigger bearing is potentially no gain if it’s closer to the bike centre line, that’s the big flaw of BB/PF30 imo. (68mm shell but internal bearings)
