I have the 2015 bike and ditched the standard shock (RS Monarch)….nothing wrong with i but i’d read on American forums that the standard 200 x 51 dimensions are conservative and the bike will take a 200 x 57 taking rear travel from 140mm to around 155mm….coupled with a 160mm fork up front you’ve then got quite a beast without the weight and length of the Giant Reign which has similar travel but is heavier and longer.
So….i found a nearly new X-Fusion O2 shock in 200 x 57 dimensions and had the LBS fit it for me, they said it was easy and there werent any problems with clearance now it has an additional 15mm or so of rear travel.
Why X-Fusion?….i’m OCD when it comes to bike parts and i was running an X-Fusion Slant fork at the time, no other reason than that!…but i can happily say the O2 shock is easily as good as the RS Monarch that came off the bike.
The bike was bought as a frame only but effectively runs in SX guise with 160mm forks (Giant sell one with 160mm forks called the SX but charge a premium for it, i decided i could do it better and cheaper)….interested in the post above about a coil shock, thats an itch i’ve been wanting to scratch for a while.
Kiksy, did it go on ok or did you have to file bits out of the way, use offfset bearings etc?
Please please tell me it just bolted straight on !?!?
