I thought I’d have a go at building my own having seen the inspiring threads on here.
My background is totally office based job l, never attempted anything like this before so this was a build based on making it up as I go!
I originally wanted a 6m x 3m summerhouse type build but the wife killed that idea
First was building the timber base. I hate abandoned concrete pads so wanted a timber base in case we ever demolish it.
That was quite easy to build.
Next was levelling it and putting 19mm osb on the base. Again pretty easy and my youngest gave it a thumbs up so I guess I did ok 🙂
Build the sides next. Hat was quite time consuming with the sides being sloping and all bit went ok. The window was left over from a previous garage conversion we had builders do.
Roped my dad in to help me erect it all.
And finally started the roof. 12mm osb. Not sure on the covering, felt seems a bit boring so am currently looking for alternatives.
Next week will be the cladding, and some kind of door.
Nice work. What are you cladding it with?
my last one I used some builders steel band stretched tight and fixed in cross patterns on the outside of the walls before cladding for a bit of cheeky triangulation.
If you’re cladding with something pretty solid then it’s probably not needed but it does add a bit of rigidity I found.
Kayak – I think it’s going to be clad in featherboard to match the garage next to it. Nice and easy and relatively cheap as well.
Dt78 – I built the frame for the base Thursday and everything else was done yesterday. Started at 10 yesterday and knocked off just before 3 for the school run so not really a whole day!
looking good ,is it too late to suggest another slab at each corner to lift base off the grass? should extend life a bit still got a way to go to catchup with shed in background
Built one a couple of weeks ago with my neighbour who’s a proper chippy so knows what to do.
Only real difference to the way you’ve done it is we built the sides individually including getting some of the cladding on before erecting. He was totally anal about getting the sides square (measure the diagonals and adjust) and then doing a few lines of cladding to stabilise it and keep it square.
I would suggest getting it up higher off the grass, you need to get some ventilation flow under neither there or else your timber will just sweat and rot in no time at all, especially the osb floor Base
I’ll take a photo later but the ground slopes away towards the rear of the base so here is a gap under there for about 75% of the length. Think that will be ok?
The base layer of wood is tantalised so should be ok on the floor I thought? Or will it still rot away quickly? It’s only the front on the floor and I could still feasibly raise it a bit if needed.
Fence posts last 10 years or so before the break where they go in the ground. That’s a lot nastier than just touching. I’d guess 20-30 years or so, and even then the rest of the structure will probably be quite happy even with a rotten base.
Posted 6 years ago
Viewing 19 posts - 1 through 19 (of 19 total)
The topic ‘New shed build, first timer…:’ is closed to new replies.
