Viewing 20 posts - 1 through 20 (of 20 total)
  • New rear mech, XT Or Zee
  • captaindanger
    Time has come for a new mech, will be 1×10 so I only need short cage. Any advantages in the xt over zee, or is it just the letters? Weight is the same, both change gear….
    honourablegeorge
    Zee has shorter cage, XT better quality IME
    spacehopper
    the Zee has a back plate made of soft cheese… (it bent in a very minor spill..)
    and i found it right at its limits of comfort on an 11-36
    XT every time for me..
    much more solid back plate and the medium cage copes better with an 11-36..
    richmtb
    XT. If you are running 11-36 and have any amount of chain growth Zee might struggle.
    You get proper bearings on the jockey wheels too
    superstu
    Useful replies as I’m about to buy as the same, thanks
    chiefgrooveguru
    There isn’t a short cage XT, only medium. But as the (super) short Zee can’t handle 11-36 plus reasonable chain growth I’d go medium cage – and buy SLX instead!
    tmb467
    XT if you ever plan to run an extender on it
    In fact XT every time – zee is just awful build quality
    Edit: just to add to CGG’s post – for the cost of XT over SLX I’d pay it just to get decent jockey wheels and a better clutch. You may decide otherwise cos SLX is still good value (basically medium cage Zee)
    pitchpro2011
    I’ve had all three, XT all day long,then Slx, zee last. XT worth the couple extra quid for the jockey wheels alone.
    captaindanger
    Great, thanks, there’s certainly a consensus on this one!
    mindmap3
    My how Zee mechs seem to be lasting pretty well and work loads better than the Sram clutch mechs that I was running before. Both are run with an 11-36 cassette and one on a full suss. They’re so cheap, if owt happens I won’t be that bothered.
    chiefgrooveguru
    What’s the benefit of bearings in jockey wheels over bushes? I presume they spin a fraction easier but they don’t seem to like wet weather as much!
    motozulu
    Last Zee I had on a 1×10, 11-36 was faultless.
    bluebird
    This is interesting, what’s reasonable chain growth? A few of us run 11-36 with a Zee short cage on different full suss bikes without any problems.
    captaindanger
    I have 11-36 on a helius AC and have not noticed any chain growth issues. Generally won’t be in a low gear if the suspension is being used through much I its travel so I suspect it may be a theoretical issue not borne out in the practicality of riding the bike
    perthmtb
    Just like to point out that the clutch is exactly the same in XT SLX Saint Zee and Deore. Only XTR gets a slightly different design of clutch.
    continuity
    I replaced an XT non-clutch with a Zee clutch, swapped the jockey wheels over when I did it and sold the XT.
    I haven’t noticed anything but a quieter drive-train since. No issues with chain growth at all on an 11-36 and 32t. Might throw a 40t into the mix and see how it does, but I’d probably need a new chain.
    I haven’t taken the bike to the alps and thrown the mech into any rocks though, so I can’t comment on the strength.
    astrozombies
    My zee coped *okay* with an 11-36 1×10 set up, but lots of chain slappage in top gear.
    Now i’ve gone 11-40 i need a longer cage, so have bought a mid cage XT.
    That’s on a spesh enduro ’12 with reasonable chain growth
    psycorp
    I’ve had 4 Zee mechs on my bikes, not had a problem with any of them. The one on the hardtail has coped with all manner of mud and crap in the last 3 months too.
    tmb467
    perthmtb – Member
    apologies for my poor memory…you are of course correct
    old posts
    perthmtb
    old posts
    Ha! I’d forgotten about that thread. I got a bit excited about it back then didn’t I – must’ve been off my meds 😆
The topic ‘New rear mech, XT Or Zee’ is closed to new replies.
