Viewing 8 posts - 1 through 8 (of 8 total)
  • New Pike maxle adjustment. Is it just me, or…..
  • agentdagnamit
    …is it harder than the manual says to clock the lever properly? I cant budge mine at all and it’s stuck at a pretty stupid angle when tightened up.
    Tried compression by hand and against the floor – it pushes in but the head wont turn.
    ChunkyMTB
    It’s just you 😮
    scaled
    Isnt there a little grub screw thing in the middle of it to adjust it?
    nickdavies
    I could be wrong, but i’m pretty sure mine pulls out to adjust? It was dead easy either way.
    agentdagnamit
    The tech video by SRAM shows the guy compressing the spring under the lever and rotating it easily by hand. Mine wont move. There is a lot of grease under there (straight out of the box), maybe that is stopping it compressing and turning.
    matther01
    Took a couple of mins to figure out but it is just like the sram guide
    agentdagnamit
    Dont it, it needed about 100lb of pressure to compress the spring the first time, now it moves easily. cheers all.
    ninenailspete
    I couldn’t get mine to adjust, even with loads of pressure. It was quick and easy to get it replaced under warranty.
The topic ‘New Pike maxle adjustment. Is it just me, or…..’ is closed to new replies.
