Northwind: It sounds like the same one you are referring to as there is not enough metal around the cam, the corners of which have now bent.
Actually it sounds like you have the previous version, looks like this?
https://static.evanscycles.com/production/components/forks/product-image/969-638/rockshox-maxle-lite-replacement-thru-axle-na-EV136166-9999-1.jpg
If it is, you can grind/file those shoulders square again and it’ll be fine (not to be a prick, but it’s half bad design and half user error, I’ve never seen one get damaged when used properly but it’s very easy to damage it if you don’t engage the lever properly- and yep I have damaged one myself exactly that way…)
I think the new one’s worse tbh, it can break even if you do everything right.
