Amplebrew, many thanks for that – what did you do ?
Crell, most of the time I just ended up redoing things cos I second guessed myself incorrectly (routing for rear derailleur being one – it does go inside the rock guard !
Direct mount derailleur – when in small front chainring the chain touches the bottom of the front derailleur when in the lowest 4 cogs on the rear. Thought I’d have to rotate the derailleur off level to cure. In fact sag takes care of it when sat on the bike.
Shortening the stealth hose is a PITA.
The bike is 160. Stealth reverb from Hi Ike in Germany in 34.9 flavour .
Opted to go SRAM but the frame came with XT clutch rear derailleur and the relevant rock guard (just in case you’re interested).
I may go for the triple cable clamps on the down tube as I have the stealth outer to deal with – at the mo it’s just cable tied to the rear brake outer. The clamps are £30 or so which is a bit steep, but then so is everything g Liteville or Syntace !!
