Not long moved into a bungalow built in the 70s – when we came to measure up I asked the seller where the stopcock was, he didn’t know, bit odd I thought.
Original gas boiler, gravity fed system, with a cold water tank in the loft and a hot water tank in a cupboard below it downstairs. The kitchen doesn’t appear to be in the original position – the house was extended in the 1980s and I guess things were rearranged, again the seller wasn’t sure.
Individual stopcocks beneath WC cisterns, but no stopcocks beneath sinks (above the floorboards at any rate).
I’ve found a stopcock behind the hot water tank that shuts off the kitchen cold water tap, and another one in the loft that stops the supply to the cold water tank. No stopcock on exit from the tank, so I guess I need to empty that to stop cold water flow to the non-kitchen taps.
The hot water’s got me a bit stumped though. I think there’s a stopcock on the cold pipe feeding the hot tank but I’m not certain that’s what it does.
I want to replace some taps, so want to shut off both hot and cold water. I can’t find a stopcock exiting the hot water tank, so I guess what I need to do is switch off the boiler and hot tank immersion heater, shut off the cold supply, empty the cold tank, then empty the hot tank. Does that sound right/normal/sensible?
I’m a bit hesitant about emptying the hot tank (not sure why…) and it seems strange to me that there aren’t stopcocks that allow me to shut the supply off without draining either tank, but I can’t find any. Can’t get under the floorboards near the boiler without undoing a big laminate jigsaw puzzle, so keen to avoid that if I can.
After years of living in weird old houses, I thought a more modern place would be dead simple!
