I’ve just got a new set of wheels built up with Hope Pro III Mono hubs and with the rear wheel firmly done up in the frame, if I push the wheel side to side for about 1/4 of the way around there is a small amount of movement going on which feels like loose bearings. I am sure it is not flex in the wheel, nor is it due to the wheel not being done up tightly in the dropout.
Anybody experienced the same or have ideas as to what the cause and solution could be? This is straight out of the box, so should I just put some miles on them and see if it settles down or I’m wondering if the bearings are not quite set right in the hub and therefore it would be best to resolve before I start using them (or some other issue which potentially requires a return to Hope).
Thanks
