Id guess you’re going to have to make a compromise somewhere there. 67deg HA, take a beaging AND comfy. At least you’ve not asked for it to be cheap
I suspect if you changed your wants from a 67deg HA’d 120mm bike to 68/120 or 67/140 you’d have more choice to go at? Unless you’re considering an angle adjust h/set
Not sure what the angles are on the 456evo but IIRC 456s aren’t the comfiest ride, nor Orange P7s?
Guessing you want to be considering things like (Ive ridden none of them so no idea on comfy):
Cotic Soul
Cotic BFe
Dialled PA
Dialled Alpine? Or are they 130mm+?
Genesis Altitude/Latitide (not Alptitude, unless youll go to 140mm)
Sanderson Life perhaps
Charge something, not the duster. STmag had one recently. Said it was very slack
Pipedream R853 Sirrus maybe?
Other high spec tubed stuff in steel
Ive a Sanderson Life with 120mm forks (Around 68deg HA) pretty comfy and seems fairly downhill capable despite thin diameter tubes. Is alright at small-medium ish drops, a long ETT 20″ frame with 90mm stem aren’t the most conducive to feeling at home in the air
Not the best climber with 120mm forks, though I think thats down to the stupidly slack seatangle. ETA on the fork (a lockdown) helps when its steep, but worse when rough ..
I cant say it gets that much of a beating as I use it as a XC hardtail most of the time, only when its acting as spare bike when the suss bike is down that it gets taken to more jumpy and rocky places
