There were well thought of as far as I know, just check with the shop, what bits will swap straight over and what will need to be replaced… as it doubtful everything will just fit.
Eg: Seat post, headset type, front derailiers, brake mounts, might be all different sizes.
Little things like this will add to your simple frame swap/upgrade costs.
If you could flog your old bits (if there any good) & add the upgrade/frame costs, you might be coming out with the same money for a end of year bargain.
The main concern nowadays for ‘older’ frames, that I see is, getting new straight steerer fork (2012 camber is 1 1/8 top & bottom). Maybe not an issue for you now, but what about next year or the year after when yours dies & you need to replace it?
