Hi chaps,
I noticed this about two weeks ago on my new 140 RLCs, but decided that the knocking was down to not storing the bike upside down.
With the front brake on, and rocking the front end – as you would to check for headset play, you can feel the stanchions moving very very slightly with your finger between them and the brace.
I know a little play is supposed to be normal, as the oil between the stanchions and the bushes closes the gap – and they will dry out over time.
The rebound now doesn’t slow the fork as much as you should, and whistles instead of making a sucking noise. Lockout works fine though.
Is this an indication of not enough oil in the lowers? I was going to make a trip to see LoCo, but rather than pester him wanted to see if anyone has had this same issue and sorted it at home.
Ricks
