Hi,
I’ve got some new Suntour Epicon X1 Lite forks (100-150mm travel) on the way to me, and was wondering whether to strip and rebuild them with new oil as soon as I get them. I’ve heard “Not enough oil in the forks from factory, wore stanchions instantly” a few times about Fox forks (Though I have no idea if it’s a common problem with all makes) and as the forks I’m getting are the 2012 model they’ve probably been sitting in a warehouse for quite some time, which won’t exactly help. And the oil in them will probably be cheap stuff anyway. So any advice would be great, please.
If they do need rebuilding etc. What wattage of oil should I use? I’m about 75kg, ride XC and will have the forks set to 120mm if that helps. I’ll be using motorbike fork oil, I’m not getting ripped off by mtb prices.
