Cheers, the custom Slik decals on the forks help with that!
I love the DB, slight weight penalty but more than makes up for it in boulder swallowing ability, plus the climb switch gives amazing traction pretty much anywhere.
The only piece of advice with 350s is as soon as you get them, take them apart, add oil to lowers and grease to seals as there are lots of reports of dry forks, mine had about 2ml in one leg and nothing in the other, should be 15ml in each. Then turn them upside down and leave them overnight. Also while they’re aprt you can put an o ring on the stanchions as there is no sag indicator for some reason!
