Hi all.
Just recieved and fitted new Elixir 5 brakes to replace my old Elixir R. The new brakes are fitted with a hinged clamp with a sinlge bolt going through the brake body.
The old brakes were fitted with the traditional split clams with two bolt. On the clamp body of the old clamp was an add-on to fit my x9 shifter to the same clamp (matchmaker?)
However, with the new hinged clamps fitted the is no attachment to screw in the x9 shifter. I now have no way to attach the shifter!!!
Can someone explain how this new system works. I’m a bit confused about the different matchmaker clamp system. From looking around I think I’ve found a new clamp that will work but it’s £30!!! I’m sure all I need is a tiny additional piece to add to the new hinge somehow that I already have…
I can’t see anywhere that sells spares.
Does that make sense???!!!!! 😕
