Viewing 18 posts - 1 through 18 (of 18 total)
  • New car build time?
  • ask1974
    I’ve had a new car on order for a few months and apparently they’ve started building it, should be in the UK for the end of the month 😀
    Got me thinking though, how long does it take a big car brand (VW in this case) to actually build a car leaving aside what ever tests are carried out post build. I honestly have no idea but I would assume fairly quickly. Anyone in the know?
    tomhoward
    Hours.
    GJP
    I recall a number of years ago it took Toyota and VW about 37 hours to build a car. It then took VW about the same amount of time to QA the car and sort out all the issues, still to have a car less reliable than Toyota. Toyota had QA and the TQM, Lean etc principles sorted.
    These figures are quite old ie several years and VW has no doubt moved on a lot more than Toyota in the intervening period. Bastid Germans (ie Checks) still managed to build me the wrong car just over a year ago, so they have so still have some basic sales order to manufacturing comms to be sorted.
    Will be very interested to here from those with more up to date info.
    seven
    Do you mean assemble the already assembled parts or the whole process of building each part then assembling?
    porter_jamie
    how often they come off the line – at Halewood they were making 90 escorts an hour…
    legend
    oh I think you may be massively disappointed at the amount of testing your car doesn’t get before you’re handed the key!
    porter_jamie
    what would you think if your brand new car had 45 miles on it? or 75? or more?
    GJP
    90 per hour equates to 750,000 per annum assuming 24×7 x 50’weeks (2 weeks shut down)?
    porter_jamie
    they told me that was the most they ever made. im not sure it they did 3 shifts or not. presumably they kept the volume down by going on strike every other week.
    when I was there they made an x type every 2 odd minutes
    legend
    porter_jamie – Member
    Am I being supplied with a full set of test results showing why it has those miles on it? It’s not the way the industry works, but if every car came like that nobody would bat an eyelid (obviously)
    prettygreenparrot
    That sounds like a long time to wait for a car. Did you time it so it’d have new, late 2013, plates on it?
    GJP
    Ford focus sales jan to June 2012 were 489,616 (world wide figures). Not sure what this tells us?
    ask1974
    This may be my first (brand) new car but I’m pretty realistic about the odds of having a load of problems, fingers crossed it’ll not happen but best be prepared hey… Still doesn’t dampen the excitement!
    Wouldn’t bother me in the slightest.
    ask1974
    Nope, didn’t even cross my mind. I was quoted 9-12 weeks and we’re around ten now, when do the plates change?
    legend
    That’s not what I meant. The quality (or lack thereof depending on the brand) is controlled by the process, not by testing and fault finding. Therefore you should still get a quality product at the end, which has been closely controlled throughout the supply chain.
    On the other hand, the industry I work in builds highly complex kit in very low numbers (compared to the motor industry, and most other industries for that matter). So tests things to the hilt before letting the customer get their hands on it.
    thegreatape
    I thought they could reset the clock to wipe off some miles. Up to a point. On some piston heads thread is where I read about it.
    TheGingerOne
    When I’ve bought new cars or when my parents got them when we were kids, they usually had 4 to 7 miles on the clock. This would be from them moving around the factory, dock, ferry, dock, distribution centre, dealership etc.
    cr500dom
    The Lion V6 Diesel (For Jaguar / Landrover) engine line at Dagenham, had a complete engine coming off the line every 44 seconds when I was there a few years ago.
    That’s complete and hot tested.
    8)
The topic ‘New car build time?’ is closed to new replies.
